rseche
May 31, 2020Aspirant
Readynas 104 stuck on normal boot
My Readynas lost power and now when it boots up it's stuck on boot menu. When I press the backup button to cycle through the options it gets stuck at normal, that is "boot menu normal". I've unplug ...
- Jun 13, 2020
That sounds like a possible power problem. But quite possibly within the NAS where it converts the 12V from the brick to the internal working voltages, not the external brick. Probably no need to panic, but you should pay close attention for at least a while, especially to any voltage warnings in the logs.
rseche
No. It doesn't give an error no disk installed, it always boot up to the boot menu. When i press the backup button, its stuck on normal. Using RAIDar and readycloud, there's no device found on the network.
