rseche's avatar
rseche
Readynas 104 stuck on normal boot
My Readynas lost power and now when it boots up it's stuck on boot menu.  When I press the backup button to cycle through the options it gets stuck at normal, that is "boot menu normal". I've unplug ...
  • Sandshark's avatar
    Sandshark
    Jun 13, 2020
    That sounds like a possible power problem.  But quite possibly within the NAS where it converts the 12V from the brick to the internal working voltages, not the external brick.  Probably no need to panic, but you should pay close attention for at least a while, especially to any voltage warnings in the logs.
ProSupport for Business
