tasone
Sep 23, 2019Aspirant
ReadyNas 104 Volume inactive or dead
I am hoping someone can help me. I was not able to access my network share that i have setup on my Readynas So I logged into my Readynas 104 and everythinig looked ok, so i did a quick reboot...
Sandshark
Sep 23, 2019Sensei - Experienced User
On the Volumes tab, how many volumes are shown (typically, you'll see "data" "data-0", etc.)?
On the Performance tab, hovering the mouse over the dot for each drive, which ones say they are a part of which volume?
- tasoneSep 24, 2019Aspirant
Sandshark wrote:On the Volumes tab, how many volumes are shown (typically, you'll see "data" "data-0", etc.)?
Hi
On the volumes tab their is only one volume showing the cleverly name "Volumeone" (all showing red)
Disk 1 - is part of volumeone
Disk 2 - is part of volumeone
Disk 3 - is part of volumeone
Disk 4 - is part of volumeone
On this tab all disks are showing as green with no errors.
Thanks
Andrew- StephenBSep 24, 2019Guru - Experienced User
Can you download the full log zip file, and post the contents of mdstat.log here? Just copy/paste it into a reply (the forum won't accept .log files). Don't post a downloadable link to the full zip, as there is some stuff in there that shouldn't be publicly posted.
- tasoneSep 24, 2019Aspiranthere is the log file mdstat.logPersonalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md127 : active raid5 sdd3[0] sdb3[2] sda3[3] sdc3[4]
11706506496 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/4] [UUUU]
md1 : active raid10 sda2[4] sdc2[3] sdd2[2] sdb2[1]
1046528 blocks super 1.2 512K chunks 2 near-copies [4/4] [UUUU]
md0 : active raid1 sdd1[0] sdc1[4] sdb1[2] sda1[5]
4190208 blocks super 1.2 [4/4] [UUUU]
unused devices: <none>
/dev/md/0:
Version : 1.2
Creation Time : Thu Sep 10 12:41:44 2015
Raid Level : raid1
Array Size : 4190208 (4.00 GiB 4.29 GB)
Used Dev Size : 4190208 (4.00 GiB 4.29 GB)
Raid Devices : 4
Total Devices : 4
Persistence : Superblock is persistentUpdate Time : Mon Sep 23 18:40:06 2019
State : active
Active Devices : 4
Working Devices : 4
Failed Devices : 0
Spare Devices : 0Consistency Policy : unknownName : 2fe64c78:0 (local to host 2fe64c78)
UUID : 7c69389f:26cc0e69:b33e47e8:1b7c9c3f
Events : 1791Number Major Minor RaidDevice State
0 8 49 0 active sync /dev/sdd1
5 8 1 1 active sync /dev/sda1
2 8 17 2 active sync /dev/sdb1
4 8 33 3 active sync /dev/sdc1
/dev/md/1:
Version : 1.2
Creation Time : Mon Mar 11 13:54:24 2019
Raid Level : raid10
Array Size : 1046528 (1022.00 MiB 1071.64 MB)
Used Dev Size : 523264 (511.00 MiB 535.82 MB)
Raid Devices : 4
Total Devices : 4
Persistence : Superblock is persistentUpdate Time : Mon Sep 23 17:41:48 2019
State : clean
Active Devices : 4
Working Devices : 4
Failed Devices : 0
Spare Devices : 0Layout : near=2
Chunk Size : 512KConsistency Policy : unknownName : 2fe64c78:1 (local to host 2fe64c78)
UUID : c612366e:755998df:e3e83b5b:953c00f9
Events : 42Number Major Minor RaidDevice State
4 8 2 0 active sync set-A /dev/sda2
1 8 18 1 active sync set-B /dev/sdb2
2 8 50 2 active sync set-A /dev/sdd2
3 8 34 3 active sync set-B /dev/sdc2
/dev/md/Volumeone-0:
Version : 1.2
Creation Time : Thu Sep 10 14:09:36 2015
Raid Level : raid5
Array Size : 11706506496 (11164.19 GiB 11987.46 GB)
Used Dev Size : 3902168832 (3721.40 GiB 3995.82 GB)
Raid Devices : 4
Total Devices : 4
Persistence : Superblock is persistentUpdate Time : Mon Sep 23 18:25:08 2019
State : clean
Active Devices : 4
Working Devices : 4
Failed Devices : 0
Spare Devices : 0Layout : left-symmetric
Chunk Size : 64KConsistency Policy : unknownName : 2fe64c78:Volumeone-0 (local to host 2fe64c78)
UUID : 527ab021:cd91839c:042685ab:432b4a60
Events : 14117Number Major Minor RaidDevice State
0 8 51 0 active sync /dev/sdd3
4 8 35 1 active sync /dev/sdc3
3 8 3 2 active sync /dev/sda3
2 8 19 3 active sync /dev/sdb3
