Leothlon
Oct 13, 2015Aspirant
Readynas 104 webinterface not starting
Hi, My webinterface wont start, browsing the forum people say os reinstalls have worked for them but i have tried that and it does not. I am not sure if the problem came from updating to 6.2.2 or f...
- Oct 14, 2015
It looks like you have hit an old bug that was present on 6.2.2 where uninstalling an app breaks apache.
Sending you a PM.
BrendanM
Oct 14, 2015NETGEAR Expert
For some reason, I can't see the log output you posted.
Could you send the full system logs? Details here: http://kb.netgear.com/app/answers/detail/a_id/21543
- LeothlonOct 14, 2015Aspirant
i put the log text in spoiler tag to avoid " wall of text ", anyway the output from " tail /var/log/frontview/error.log "
is:
[Fri Jan 23 10:19:02 2015] [error] [client 192.168.1.227] File does not exist: /frontview/dashboard/ldMachine\\jobs\\R6UI-6.1.x\\workspace\\_gen2flat\\trunk\\builder\\trunk\\_deploy\\css\\wizard_1.0.2.64_base64.css, referer: https://192.168.1.33/admin/
[Fri Jan 23 10:19:02 2015] [error] [client 192.168.1.227] File does not exist: /frontview/dashboard/ldMachine\\jobs\\R6UI-6.1.x\\workspace\\_gen2flat\\trunk\\builder\\trunk\\_deploy\\extjs\\ext-all.js, referer: https://192.168.1.33/admin/
[Fri Jan 23 10:19:02 2015] [error] [client 192.168.1.227] File does not exist: /frontview/dashboard/ldMachine\\jobs\\R6UI-6.1.x\\workspace\\_gen2flat\\trunk\\builder\\trunk\\_deploy\\extjs\\adapter\\ext\\ext-base.js, referer: https://192.168.1.33/admin/
[Fri Jan 23 10:19:02 2015] [error] [client 192.168.1.227] File does not exist: /frontview/dashboard/ldMachine\\jobs\\R6UI-6.1.x\\workspace\\_gen2flat\\trunk\\builder\\trunk\\_deploy\\css\\browse_1.0.2.64_base64.css, referer: https://192.168.1.33/admin/
[Fri Jan 23 10:19:02 2015] [error] [client 192.168.1.227] File does not exist: /frontview/dashboard/ldMachine\\jobs\\R6UI-6.1.x\\workspace\\_gen2flat\\trunk\\builder\\trunk\\_deploy\\css\\frontview_1.0.2.64_base64.css, referer: https://192.168.1.33/admin/
[Fri Jan 23 10:22:30 2015] [error] [client 192.168.1.227] Connect failed, referer: https://192.168.1.33/admin/
[Fri Jan 23 10:22:30 2015] [error] [client 192.168.1.227] Error connecting to readynasd -2, referer: https://192.168.1.33/admin/
[Fri Jan 23 10:22:30 2015] [error] [client 192.168.1.227] 16767:dbbroker.cgi.c:513 , referer: https://192.168.1.33/admin/
[Fri Jan 23 10:22:30 2015] [error] [client 192.168.1.227] Connection fail., referer: https://192.168.1.33/admin/
[Fri Jan 23 10:22:30 2015] [error] [client 192.168.1.227] Premature end of script headers: dbbroker.cgi, referer: https://192.168.1.33/admin/as for the full system logs link you sent it describes how to get the logs from the webinterface.. but the problem is that the webinterface dont start so cant do that..
Where can i access the logs via ssh?
i also seen people ask for the output of " df -h " and that is:
root@nas-4drive:~# df -h
Filesystem Size Used Avail Use% Mounted on
rootfs 4.0G 870M 3.0G 23% /
tmpfs 10M 4.0K 10M 1% /dev
/dev/md0 4.0G 870M 3.0G 23% /
tmpfs 248M 0 248M 0% /dev/shm
tmpfs 248M 2.1M 246M 1% /run
tmpfs 248M 0 248M 0% /sys/fs/cgroup
tmpfs 248M 0 248M 0% /media
/dev/md127 8.2T 7.5T 457G 95% /data
/dev/md127 8.2T 7.5T 457G 95% /apps
/dev/md127 8.2T 7.5T 457G 95% /home
/dev/md127 8.2T 7.5T 457G 95% /run/nfs4/data/F
/dev/md127 8.2T 7.5T 457G 95% /run/nfs4/data/S- BrendanMOct 14, 2015NETGEAR Expert
Ah, sorry, my bad.
Can you run RAIDar - http://kb.netgear.com/app/answers/detail/a_id/20684/~/readynas-downloads#raidar and see if the 'Download logs' option from there works for you? If yes, then send the logs as per the earlier link.
If the logs download via RAIDar doesn't work, let me know.
Sorry for the long delay but i had to remote into my homepc and run raidar there...
But there is no download logs there only "Admin page" and "browse", then the normal rescan buttons and such...
Not sure if this is depending on what nas i have or something? i use:
raidar version 6.0
nas model: readynas 104
firmware 6.2.2
is there noway i can get the logs over ssh?
- May 25, 2022Anonymous
