Martok867's avatar
Martok867
ReadyNAS 104 will not shutdown
ReadsyNAS 104
4 x 2TB
Unit will not shutdown or reboot even if I leave it for 12 hours.
I have to pull the plug and restart it this way - not a good option.
Any ideas?
No apps running, nothing special as this is just a storage device for streaming videos and the like.
No streaming is taking place at the time..........
Thanks
  • It locked again also with 6.2.2 so I decided to disable the virus checker and from that moment it seems that works.
    What do you suggest? Leave like this and test some days or move to 6.2.4?
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    I guess leave it for some days and then update to 6.2.4 and test on that as well.
  • I personally don't see the point of the virus checker on the RN10x boxes, it really slows down your NAS and has no added value (just keep properly updates scanners on your PC's)
    Sent from my SM-P900 using Tapatalk
  • Unfortunately it happened again.
    Last night I decide to update to 6.2.4 because I was seeing strange things (movie stop every 15 minutes and then restart, seem that lost the network connection for few minutes).
    After the update it start again the same situation (lost network connection and impossible to restart the NAS, possible only unplug the power cord).
    It happens 2 time in 5 minutes and one time the booting stop and was necessary to unplug again the power cord because the booting was frozen.
    Now it's still working after 10 minutes but I don't think it's a normal situation.
    Can somebody help me?
    Just an updating: it happened again after half hour; in this way the NAS It is unusable
ProSupport for Business
