pyschometal
Apr 06, 2018Aspirant
Readynas 204 Hot Swap Question
Hi, I have a dilemma which I am sure there is a simple explination but, here goes anyway. I have a Readynas 204 with 4 x 4tb drives in raid 0 and I want to start upgrading them to 6tb or 8tb driv...
Apr 07, 2018Guru - Experienced User
If you have only one volume, then you'll need to back everything up, Then
- destroy the current volume
- insert the new disk
- create a new volume
- reconfigure all the shares
- reinstall any apps
- restore the data from your backup
If you have four volumes (which is much better), then you need to back up the volume you are upgrading. Then
destroy that volume
- create the new volume
- reconfigure the shares on that volume.
- restore the data from the backup.
Using redundant RAID makes expansion much simpler.
pyschometal
Apr 07, 2018Aspirant
Thanks for the reply.
I am making my methodology overcomplicated but basically, what I am trying to do is transfer the data on a full drive onto a new higher capacity drive using the nas itself but, I have 4 drives populating the nas already.
What I want to know is, what will happen if I pull a working drive/ volume out of the nas to make space for the new drive, transfer the data and pull the old drive out. Then re-instal the drive I had to pull in the begining.
Will the drive function as before? Will I lose the data?
- StephenBApr 07, 2018Guru - Experienced User
How many volumes do you have now? If you only have one RAID-0 volume on the volumes tab, then you will lose all your data when you remove one of the drives.
- pyschometalApr 07, 2018Aspirant
My mistake, I thought I had Raid 0 but I actually have 4 volumes in JBOD. Sorry I thought Raid 0 meant no raid.
You might be able to
- power down
- remove a drive from slot A
- power up, and install a new drive in that slot
- create temporary share names for each share
- use backup jobs to transfer data from slot B
- destroy the old volume
- rename the temporary shares
- power down, and insert the original disk in slot A
- power up.
I haven't tried it though, and if it doesn't work you will lose some data.
One potential problem - one of your volumes has /.apps and /home on it. If you destroy that volume, the system will first move that stuff to a new drive. But if you simply remove it, I don't know how it will behave.
