Callahan22
Apr 27, 2016Follower
ReadyNAS 204 won't shutdown on schedule - Do_exit+8c4 error
Hi, ReadyNAS model : RN204 Firmware : 6.4.2 My new ReadyNAS 204 fails to shutdown on it's schedule. The reason, I have since discovered, was likely down to an incompatibility with my switch ...
- Apr 27, 2016
Hi Callahan22,
Welcome to the community!
I believe this issue has been addressed by the latest Firmware (beta) available. We encourage you to try this and let us know if your issue goes away.
Changelog
- [Beta 1] Fixed occasional shutdown failures with Wake-on-LAN or Power Schedule enabled. (RN202/204/212/214)
Kind regards,
BrianL
NETGEAR Community Team
BrianL2
Apr 27, 2016NETGEAR Employee Retired
Hi Callahan22,
Changelog
Kind regards,
BrianL
Callahan22
May 05, 2016Follower
Hi Brian,
Sorry for the delay in replying. I wanted to give it a week of running to see if this resolved the issue. It seems to have fixed it. I've not tried rebonding the NICs to see if that causes the same issue but will try to get some time soon to test this also.
Thanks for your help with this.
