ajkainth
Oct 03, 2017Aspirant
ReadyNAS 212 \ snapshot note created automaticly
I have configured to create daily snapshot for a folder but it doesn't create even there is no error in log. If i create snapshot manually then it creates normally.
- Oct 11, 2017
These logs you provided us show that the option "Spin up disks to take scheduled snapshots" is not enabled. Go to System > Power > Disk Spin-down, check the box "Spin up disks to take scheduled snapshots" -- your disks are spun down, can't take snapshot, then 5 minutes later your disks wake up for backup jobs.
Oct 03, 2017Guru - Experienced User
What firmware are you running?
Is the NAS on a power schedule?
Is disk spindown enabled?
Is the share set to "only take snapshots on changes"?
ajkainth
Hi Stephen,
Thanks for support.
Please find here with responce for your points:
1. What firmware are you running?
6.7.3
2. Is the NAS on a power schedule?
Yes On time 23 to 4
3. Is disk spindown enabled?
No
4. Is the share set to "only take snapshots on changes"?
No
- StephenBOct 03, 2017Guru - Experienced User
Thanks.
Are you using "custom" snapshots or "smart" snapshots? "Smart" snapshots are supposed to be taken at midnight, so they ought to work.
But if you choose "custom" snapshots you can set the time the snapshots will be taken. My RN524x is on a 23:00 -> 1:00 power schedule, with the snapshot schedule set to 0:00-0:59 - and that is working for me. I'm running 6.8.1 on that NAS.
- ajkainthOct 06, 2017Aspirant
Hello Stephen,
Thanks for update.
Please note i have also trried to test without any power timer, now NAS is always on mode.
But still it dosn't create snapshot even there is no any log.
- StephenBOct 06, 2017Guru - Experienced User
I think the next step is to upgrade to 6.8.1 (current firmware) and see if the behavior changes.
- Jun 06, 2017Retired_Member
