Katuhin
May 29, 2018Aspirant
ReadyNas 212 does not work. Managment service is offline
Got new NAS 212 model. When I try to connect to NAs using https://readycloud.netgear.com service can't find it.
I downloaded RAIDar and it said, that NAs is ok, got ip address, microcode versi...
May 29, 2018Guru - Experienced User
Katuhin wrote:
I downloaded RAIDar and it said, that NAs is ok, got ip address, microcode version 6.4.1 but got error
You need to update the firmware - 6.4.1 is very old and doesn't support the ReadyCloud single-sign-on.
The current firmware is 6.9.3. You can't migrate to that in one step (again your firmware is too old for that). You'll need to update to 6.5.2 and then to 6.9.3.
The software update feature in the web UI should present the 6.5.2 update first.
- KatuhinMay 29, 2018Aspirant
After default factory reset, I could find my NAS but I could not login even localy. What is the default password and username? And how I could update firmware if I could not login to web service?
- JohnCM_SMay 29, 2018NETGEAR Employee Retired
Hi Katuhin,
The default admin credential for your NAS is admin for the username and password for the password.
