naweedqadir
May 24, 2016Aspirant
ReadyNAS 312 - SMB disabled after 6.5.0 Upgrade
Hi Everyone, I had all my ReadyNAS shares configured in my Windows devices as accassible drives. After the 6.5.0 update I noticed my SMB service is disabled and it cannot be enabled. I am...
mdgm-ntgr
May 25, 2016NETGEAR Employee Retired
If you still see the problem can you send in your logs (see the Sending Logs link in my sig)?
naweedqadir
May 25, 2016Aspirant
Thanks for your Email. My Netgear system Log can be downloaded from here - https://app.box.com/s/lis8ys7le2tieztw2wtimn73cdun8r3q
Naweed
- mdgm-ntgrMay 30, 2016NETGEAR Employee Retired
Ah, naweedqadir you didn't email them in.
I'm seeing messages such as
May 24 19:56:07 NAS-QADIR readynasd[2747]: Can't load /etc/samba/smb.conf - run testparm to debug it
May 24 19:57:31 NAS-QADIR systemd[1]: smb.service: main process exited, code=exited, status=1
May 24 19:57:31 NAS-QADIR systemd[1]: Unit smb.service entered failed state.in the logs.
Can you email a config backup (System > Settings > Configuration Backup) of your system in please (see the Sending Logs link in my sig)?- naweedqadirJun 16, 2016Aspirant
Hi!
I have Emailed the details. Still couldn't find any solution for the SMB to get enabled again.
Naweed
- mdgm-ntgrJun 16, 2016NETGEAR Employee Retired
naweedqadir, I have sent you a PM. We suspect that an app perhaps may have messed with the ownership or permissions of files on the root volume.
