landungsbruecke
Dec 08, 2017Aspirant
ReadyNAS 312 cannot be accessed with LAN1+LAN2 at the same time after upgrade to FW 6.9.1
Dear community, we are running a ReadyNAS 312 connected to two networks (one via LAN1 with a fixed IP, and another via LAN2 with another fixed IP), using SMB. Until we upgraded to the current firmwa...
Marc_V
Dec 14, 2017NETGEAR Employee Retired
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
- landungsbrueckeDec 14, 2017Aspirant
I could fix the issue by indeed downgrading to my previous version 6.7.5 and the doing a OS reinstall. One thing to note might be that on eth0 we have a windows network, and on eth1 we have a OSX (Mac) network. We did a full backup before, though (but luckily did not need it).
So for me this points to some misconfiguration in the internal eth0/eth1 settings after the firmware upgrade from 6.7.5 to 6.9.1.
- Marc_VDec 17, 2017NETGEAR Employee Retired
Hi @landunsbruecke
Please note that downgrading is not recommended.
And I don't think that this is an issue with the current firmware though as we have tested it with Windows and Mac OS and we do not get the same concern, perhaps a little more information from the logs could have helped us determine the cause of the problem and resolve it.
Regards
