DaveSh
Sep 09, 2015Tutor
ReadyNAS 312 Frozen on disc replacement
Hi! I had a failed disc on the unit so decided to replace both with same size 3TB WD red drives. Replaced the first following the standard procedure. No problems, left it for a day to ensure all was ...
- Sep 11, 2015
Not as far as I know.
Some users report problems with the DM disks. Perhaps test that disk too.
Did the resync only take 1 hour with all the disks you tried?
mdgm-ntgr
Sep 09, 2015NETGEAR Employee Retired
You could try that.
It's possible that one of the new disks might be faulty. I assume you didn't test the new disks using WD Data Lifeguard Diagnostics?
Which firmware are you running?
