DaveSh
Sep 09, 2015Tutor
ReadyNAS 312 Frozen on disc replacement
Hi! I had a failed disc on the unit so decided to replace both with same size 3TB WD red drives. Replaced the first following the standard procedure. No problems, left it for a day to ensure all was ...
- Sep 11, 2015
Not as far as I know.
Some users report problems with the DM disks. Perhaps test that disk too.
Did the resync only take 1 hour with all the disks you tried?
DaveSh
Sep 09, 2015Tutor
Thanks mdgm,
No - I didn't test the new discs. Can't access the unit so not sure about the firmware. I recall updating in the last 6 months or so.
vandermerwe
Sep 10, 2015Master
Whatever you do you are going to have to test both new disks before proceeding.
Wd lifeguard extended tests take a long time.
I would power down, remove the disks, reinsert your old disk 2 (the one you exchanged second) and power on. This may get you back to the situation you were in after you inserted the first new disk. If at least one of the new disks is ok , and the old disk allows normal access to your volume, then you can try to insert a new disk again.
Could you access the data after the first disk exchange?
One hour is far too short a time for the resync to have completed, you were correct to be suspicious. Did you look and confirm that the volume was redundant at this stage?
- DaveShSep 10, 2015Tutor
Thanks vandermerwe,
Things have moved on a bit from here but to be brief, I gave up on the hot swap and have done a factory default on the machine. New disks are in place with data transferred across and seems to be working fine.
Prior to deciding this approach:
I had another two spare discs (replacements to go into another machine) which I tried in various combinations with the same end result. Each time after the first swap I would get a message that the resync was complete and the volume had been rebuilt successfully. I restarted the unit after this and the reboot was fine, but I noticed it rebuilt the volume again. When I swapped the second disc the unit would go offline/hang, with the message "please remove inactive volumes in order to use the disc #2". From there I did a hard shutdown, removed the second disc, and restarted, with the same result (system hung, please remove inactive volumes etc).
From this I figured I was unlikely to have 4 bad discs, that I was not clever enough to diagnose the problem, and the best path was the factory default. I have started running WD diagnostics anyway just to be sure. First disc no problems with the quick scan, extended scan running now. Time will tell but I suspect this is not the issue.
Is it possible that there is some difference between the old Seagates (ST3000DM001) and the new WD (WD30EFRX-68EUZNO) that prevents the disc replacement?
- vandermerweSep 11, 2015Master
- DaveShSep 15, 2015Tutor
Hi vandermerwe,
Yes the resync was fast on all discs. I just didn't stop to calculate whether it was feasible at the time. I completed a full scan on one of the new WD discs which turned up no errors, and will test the DM disc when I have time. Just very busy catching up with work at the moment. Thanks very much for your help.
