Paulus237
Mar 16, 2022Tutor
ReadyNAS 314 OneDrive with 6.10.7
I just updated to firmware 6.10.7 and then OneDrive Sync showed authentication errors I followed this solution https://kb.netgear.com/000049510/ReadyNAS-OS-6-9-Sync-with-OneDrive to fix this. But...
rimondi12
Mar 19, 2022Aspirant
After auto-updating to this firmware (10.6.7) my drive began to throw sync errors as well. Upon resync the drive completely locked up a total of 3 times, each time requiring me to hard reboot it to get it back online - couldn't even access the web GUI. It was after the third time this happened that I downgraded back to 6.10.6. After the downgrade the sync errors stopped, and the unit hasn't locked up again since. Only issue is that the lockups caused one of my 4 drives to become degraded and require a recovery. Luckily I have a RAID setup so other than the 3 days that will take nothing has been lost.
Mar 19, 2022Guru - Experienced User
I suggest running the disk test from the volume settings wheel after the current resync completes.
FWIW, I haven't run into any issues with 6.10.7 on my RN102 or my RN202 - the RN102 is using XRAID/RAID-1, and the RN202 is using FlexRAID/jbod. My various x86 NAS are running XRAID/RAID-5 and no issues with them either.
