Paulus237
Mar 16, 2022Tutor
ReadyNAS 314 OneDrive with 6.10.7
I just updated to firmware 6.10.7 and then OneDrive Sync showed authentication errors I followed this solution https://kb.netgear.com/000049510/ReadyNAS-OS-6-9-Sync-with-OneDrive to fix this. But...
Mar 19, 2022Guru - Experienced User
rimondi12 wrote:
After auto-updating to this firmware (10.6.7) my drive began to throw sync errors as well. Upon resync the drive completely locked up a total of 3 times, each time requiring me to hard reboot it to get it back online - couldn't even access the web GUI.
I suggest running the disk test from the volume settings wheel after the current resync completes.
FWIW, I haven't run into any issues with 6.10.7 on my RN102 or my RN202 - the RN102 is using XRAID/RAID-1, and the RN202 is using FlexRAID/jbod. My various x86 NAS are running XRAID/RAID-5 and no issues with them either.
Paulus237
Mar 19, 2022Tutor
I've not had any drive issues, just the Onedrive sync.
I'll give it a week (as the sync isn't mission critical) before considering going back to an older version.
