robcf's avatar
robcf
Readynas 316 - Permissions Will Not Apply To Copied Folders
Hi,
I am having issues with my Readynas 316, specifically integrating with Media Browser Server (MBS). The (MBS) has been configured to download video file images such coverart, however, it will only do so for videos where the folder was created in OS6. The coverart will not download for files which have been copied from another hard drive for example. The share is set up as below.
data/Videos/Movies/Video Folder (XXXX)/video files.............
Using WinSCP I have logged into the NAS root directory, selecting all Video folders have attempted to update the permissions recursively to '0777'. Doing so does not enable the MBS to save the image files into the video folder, however, as stated before if I create a folder in the NAS using the GUI with the same name as the origginal the coverart will download instantly.
For the reasons I stated above I do not believe the permissions are being applied, any help to identify and correct the issue would be appreciated.
Rob
  • I updated all the credentials as suggested which did not resolve the issue. Unfortunately I am going to give up and replicate all the folders copying over the image files.
    To all thanks for your help.
ProSupport for Business
