neoprodigy
Aug 27, 2015Aspirant
ReadyNas 316 | how to delete \data\home\Backup
i cant seem to delete \data\home\Backup on the admin page. nor i can find that folder on the mac Finder
- Aug 27, 2015
The folder has been deleted now.
Once the balance I am running has completed please run another from the UI, by oging to System > Volumes, selecting the volume and choosing balance.
Once that is done, I would run a defrag.
Best not to fill the volume to more than 80-85%.
I would recommend scheduling a balance every few weeks or so. I would also schedule a defrag.
neoprodigy
i dont have a user called Backup...
mdgm-ntgr
Aug 27, 2015NETGEAR Employee Retired
O.K.
Turns out that was not a home folder. Your data volume being so full could have been a factor.
- neoprodigyAug 27, 2015Aspirant
it was backing up to another NAS.. dono why it started back to same NAS.. i need to delete that backup folder to free up space
- mdgm-ntgrAug 27, 2015NETGEAR Employee Retired
I would recommend scheduling a balance every few weeks or so. I would also schedule a defrag.- neoprodigyAug 27, 2015Aspirant
how to schedule?
Under System > Settings > Volume Schedule.
- neoprodigySep 03, 2015Aspirant
if i want to delete that folder manually how should i do it?
- mdgm-ntgrSep 03, 2015NETGEAR Employee Retired
Did you try logging in via SMB as the admin user? You could have tried deleting the folder using that seeing it was just a folder not a share.
I used SSH and the rm command.
