paviles
Apr 12, 2015Aspirant
ReadyNAS 3200 boot Could not find external flash device
I have a ReadyNAS 3200 and when I attempt to boot nothing happens. When I connect a serial console I can see the unit cannot find whatever boot flash device is looking for. I have used the USB Reco...
paviles
Hmm... in the USB recovery you don't use the original USB inside the unit? If so then that is the reason as that was what I used. There is no front USB on the 3200 so I guess it should have been one of the ports in the back.
So I guess if I get a copy of the files on the original USB stick I should be good to go. Do you have them by any chance?
Thanks
Paul
Thanks
Paul
