Dale2100
Jun 04, 2022Follower
ReadyNAS 4.2.31 TLS 1.2 Issue
I'm running ReadyNAS 4.2.31 on an NVX Pioneer NAS and have started getting the TLS error on all browsers (Edge, FireFox, Chrome) and cannot connect to the NAS. Accounts allow access to shares, but n...
saudade
Jun 04, 2022Apprentice
Check out this thread.
Post #2 has the link to the firmware you should be able to use.
I resolved my issue with 4.1.16.
- StephenBJun 04, 2022Guru - Experienced User
saudade wrote:Post #2 has the link to the firmware you should be able to use.
A direct download link for the add-on you need is https://github.com/rdynsxtrs/rn4bin/blob/main/apache2/x86/Apache2_2.2.34-x86-0.2.0.bin
Note you can still access Frontview with Internet Explorer. If you can't use that, you can alternatively download an old version of FireFox. Version 94.0.2 works - just make sure you immediately reconfigure it to turn off auto-update.
