scottonaharley's avatar
Apr 17, 2022
readynas 4220 memory segmentation fault
This unit has been humming along for several years when this error started to pop up following the 6.10.7 upgrade. I am able to access via ssh but the management service is not running.  The web s...
  • scottonaharley's avatar
    scottonaharley
    Apr 20, 2022
    Upgrading to 6.10.6 brought back the problem in the same lib along with the failure of the management interface after a short period of time.
    <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<diag output>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
    • 2022-04-20 06:02:31: snapshot_monito[6361]: segfault at 30 ip 00007f1ffa430950 sp 00007f1fc7ffeae8 error 4 in libapr-1.so.0.5.1[7f1ffa413000+32000]
    Downgrading to 6.10.5 eliminated the problem.  I wonder if the clam can be updated independently of the OS.  This is from the 6.10.6 release notes:
    • Antivirus ClamAV is upgraded to version 0.103.2+dfsg.
    It looks like stability is restored at the 6.10.5 level.
ProSupport for Business
