scottonaharley
Apr 17, 2022Aspirant
readynas 4220 memory segmentation fault
This unit has been humming along for several years when this error started to pop up following the 6.10.7 upgrade. I am able to access via ssh but the management service is not running. The web s...
- Apr 20, 2022
Upgrading to 6.10.6 brought back the problem in the same lib along with the failure of the management interface after a short period of time.
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<diag output>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>- 2022-04-20 06:02:31: snapshot_monito[6361]: segfault at 30 ip 00007f1ffa430950 sp 00007f1fc7ffeae8 error 4 in libapr-1.so.0.5.1[7f1ffa413000+32000]
Downgrading to 6.10.5 eliminated the problem. I wonder if the clam can be updated independently of the OS. This is from the 6.10.6 release notes:
- Antivirus ClamAV is upgraded to version 0.103.2+dfsg.
It looks like stability is restored at the 6.10.5 level.
scottonaharley
Apr 19, 2022Aspirant
That command cleared the "volume degraded" message. I will try moving to 6.10.6 to clear the clamav tomorrow and report the results.
scottonaharley
Apr 20, 2022Aspirant
