DJ_W
Sep 08, 2021Aspirant
ReadyNAS 4312 Running Out of Space
I'm having trouble freeing up some space on my company's ReadyNAS 4312. I'm wondering if there might be some data that I'm not thinking of that I couild safely delete? We currently back up users' fil...
Sep 08, 2021Guru - Experienced User
DJ_W wrote:
I'm having trouble freeing up some space on my company's ReadyNAS 4312. I'm wondering if there might be some data that I'm not thinking of that I couild safely delete? We currently back up users' files to the ReadyNAS, but I don't think they take up enough space to fill up 27TB. Are there some temporary files/caches that I could clear out? Thanks for any help!
Do you have snapshots enabled on any shares? If you do, then I'd start by deleting the oldest. If the shares are set up to use "smart" snapshots, then I suggest changing to "custom" and explicitly limiting retention.
Once you deleted old snapshots, then you might need to run a balance from the volume settings wheel to reclaim the space.
That firmware are you running?
- DJ_WSep 09, 2021Aspirant
Unfortunately I don't have any snapshots. I am currently doing a volume scrub and will try a volume balance after that. I am running firmware version 6.9.2. I know that's old, but I have a separate issue where I can't get the NAS online to download firmware updates. Thanks for the help; I will post the results when I have them.
- SandsharkSep 09, 2021Sensei
A scrub will not free any space.
You say you have no snapshots. By default, they are on when you create a share, so you are sure you disabled them?
What is the error message you are getting? Make sure it's about the user space (usually volume /data), not the system partition, which is an entirely different problem.
Do you have any iSCSI LUNs that are also taking up space?
I was mistaken, it seems each of the shares has one snapshot. I tried deleting one but I got a message saying "Failed to delete the snapshot." I have no iSCSI LUNs set up. Balancing the volumes didn't free up any space. I'm not getting any other error messages, but the overview screen shows that I have 35GB free of 27TB. That just doesn't seem right to me, unless maybe the Windows backups are not being deleted? I have users' files backed up to the NAS through Windows backup. But I thought they deleted the oldest ones after a certain point.
