Sigorel
Jun 24, 2017Aspirant
ReadyNAS 528x connect to 2 PCs
Hello! I have two PCs running on windows 10 who are both connected to my NAS directly via ethernet cable. Everything works perfectly but I can only access the NAS from one PC at a time (the one w...
- Jul 06, 2017
Hi and thanks for the answers!
The goal of this NAS was having it connected to both PCs (with 10GbE interfaces and 6TB WDC Reds inside the NAS) to edit simultaneously 4k video on both PCs.
We ended up buying the switch, works fine now with speeds up to 400Mb/s (with 5 HDDs)
jak0lantash
Jun 24, 2017Mentor
If he wants 10GbE, then it will be $500 ^^
Sandshark
Jun 24, 2017Sensei
OK, but what speed advantage in the real world with just two users does the 10GBE really provide? I've not seen any independent speed test data.
- StephenBJun 24, 2017Guru - Experienced User
With a 528x you should get about 3x the speed of gigabit for large file transfers. At least that's my best estimate from my testing. The 62x and 71x would be faster.
So with the 528x you'd see SSD-type speeds when accessing the NAS.
