Sigorel
Jun 24, 2017Aspirant
ReadyNAS 528x connect to 2 PCs
Hello! I have two PCs running on windows 10 who are both connected to my NAS directly via ethernet cable. Everything works perfectly but I can only access the NAS from one PC at a time (the one w...
- Jul 06, 2017
Hi and thanks for the answers!
The goal of this NAS was having it connected to both PCs (with 10GbE interfaces and 6TB WDC Reds inside the NAS) to edit simultaneously 4k video on both PCs.
We ended up buying the switch, works fine now with speeds up to 400Mb/s (with 5 HDDs)
jak0lantash
Jun 24, 2017Mentor
It depends of the HDDs too. If you put a single 5400RPM green drive in there, you won't get those speeds.
- StephenBJun 24, 2017Guru - Experienced User
jak0lantash wrote:
It depends of the HDDs too. If you put a single 5400RPM green drive in there, you won't get those speeds.Correct. My measurements were done with 3x8TB WDC Reds on the 524x and 4x6TB WDC Reds on the 526x (xraid in both cases).
