Seur18
Jan 26, 2016Tutor
Readynas 6.4.1 DLNA issue - duplicated folders and missing elements
Hi. I'm an old user of Readynas, starting with the Duo and now I have a Readynas 314. The main use is for streaming content to DLNA clients and I have about 2TB of video and music files. Recently...
- Jan 31, 2016
Hi Seur18,
With this current network setup, will it be okay if you will disable the device DLNA service and have the DLNA (disabled/enabled) on the share/s too? I hope you could give it a try.
Kind regards,
BrianL
NETGEAR Community Team
BrianL2
Jan 26, 2016NETGEAR Employee Retired
Hi Seur18,
Welcome to the community!
Did you notice this problem after an upgrade to 6.4.1 or any changes that might have triggered this problem? Also, can you send us a copy of your device logs so we can take a look at your system?
Kind regards,
BrianL
Seur18
Jan 27, 2016Tutor
Yes, I noticed this problem after the upgrade to 6.4.1 but not exactly after.
First I upgraded the nas to 6.4.1 and after the reboot I move 100GB of new videos to the nas. One day after I notice that some videos are not visible by dlna client. Finally one or two days later i rescan the folder to refresh the database and after that was when I saw the root folder duplicated. Since then I'm trying to fix it.
I just have send the logs.
Best regards.
- mdgm-ntgrJan 27, 2016NETGEAR Employee Retired
If you look in upnp-av.log you will see that it didn't like one of your videos, though it seems you may have removed that video already.
- Seur18Jan 27, 2016Tutor
Thank you ,but yes, I know. I saw this one when I tried to execute the full rescan by SSH. Then I deleted it and I tried again, but with no luck.
Best Regards
- BrendanMJan 28, 2016NETGEAR Expert
It looks like you are using adaptive load balancing. Can you try disabling teaming and connect just 1 NIC and see if this makes any difference?
I have seen ALB cause problems in certain environments. I wonder if it might be confusing the DLNA clients here.
