piet8stevens
Jan 29, 2016Aspirant
Readynas 6.4.1 RN102 boot issue - OS reinstall did not help.
I have powered down my RN102 from the admin page system menu. Upon reboot, it just sits there with the power led flashing. Act, Disk 1 and Disk 2 LEDs are lit as well as a red/amber light at the back...
- Feb 05, 2016
A big thank you to mdgm. I am very favorably impressed with the quality and speed of the support.
Problem is a change I made using ssh and not a ReadyNas hardware or software problem.
mdgm-ntgr
Jan 30, 2016NETGEAR Employee Retired
There are definitely steps that can be taken before resorting to a factory default. That's a last resort.
In addition to what JennC asked, I would add that in some cases the volume read-only boot menu option can be quite useful.
I don't see any support cases for your systems so I assume you didn't contact support before doing the factory default last time. Once a factory default is done there is nothing we can do to investigate what happened beforehand.
