dreddick
Oct 12, 2016Follower
ReadyNAS 6.6.0 will not recognise USB storage device when plugged in
Since updating to firmware 6.6.0, Readynas will not recognise my USB external storage device when I plug it into the fron USB port unless I reboot the ReadyNAS. Is this a bug in the new firmware. Doe...
Ildefonse
Oct 24, 2016Aspirant
Hi ! Same issue as well. Upgraded from 6.5.1 to 6.6.0.
Actually, the USB external HD is not recognized when I plug it while the NAS is on. But if I turn it off, then plug the HD, then turn it on, it's OK.
I can also reboot the NAS.
So it's only a matter of "hot-plug".
Thanks !
Justlogical
Oct 27, 2016Guide
Can anyone give me a fix for this as having to reboot the NAS everytime you swap the USB drive is not a solution.
