dreddick
Oct 12, 2016Follower
ReadyNAS 6.6.0 will not recognise USB storage device when plugged in
Since updating to firmware 6.6.0, Readynas will not recognise my USB external storage device when I plug it into the fron USB port unless I reboot the ReadyNAS. Is this a bug in the new firmware. Doe...
FramerV
Oct 28, 2016NETGEAR Employee Retired
Ildefonse wrote:
Hello Netgear. Is something being done about this problem? Thanks.
Yes, the engineers are aware of the issue. They are working on a fix for it.
Justlogical
Nov 04, 2016Guide
Hi
Can we get an update on when Netgear think they will have a fix for this issue
- JustlogicalNov 10, 2016Guide
Hi,
Any uopdate in regarsd to this issue as we have this occuring on multiple ReadyNAS devices.
- davexyzNov 10, 2016Aspirant
I had something similar. Can you check these two things to see if it is what occurs in my situation
1) in windows when the USB Disk is plugged in and not recognised can you see it in explorer
2) when the USB Disk is plugged in and not recognised in windows explorer can you see it the share page of the NETGEAR web page as an smb share
if you can see it on the Netgear web page as SMB share but not in windows explorer then it is an issue with smb.conf in the os of the NAS
- evan2Nov 14, 2016NETGEAR Expert
We reproduced the issue, and the issue has been fixed,
