dreddick
Oct 12, 2016Follower
ReadyNAS 6.6.0 will not recognise USB storage device when plugged in
Since updating to firmware 6.6.0, Readynas will not recognise my USB external storage device when I plug it into the fron USB port unless I reboot the ReadyNAS. Is this a bug in the new firmware. Doe...
Justlogical
Nov 04, 2016Guide
Hi
Can we get an update on when Netgear think they will have a fix for this issue
Justlogical
Nov 10, 2016Guide
Hi,
Any uopdate in regarsd to this issue as we have this occuring on multiple ReadyNAS devices.
- davexyzNov 10, 2016Aspirant
I had something similar. Can you check these two things to see if it is what occurs in my situation
1) in windows when the USB Disk is plugged in and not recognised can you see it in explorer
2) when the USB Disk is plugged in and not recognised in windows explorer can you see it the share page of the NETGEAR web page as an smb share
if you can see it on the Netgear web page as SMB share but not in windows explorer then it is an issue with smb.conf in the os of the NAS
- evan2Nov 14, 2016NETGEAR Expert
We reproduced the issue, and the issue has been fixed,
- JustlogicalNov 14, 2016Guide
Hi,
Can I ask what the fix is and how we cna get the fix?
Hi Justlogical,
Sorry! I don't know the official FW release schedule.
The FW fix has been verified internally.
We will have BETA FW soon with the fix included.
- johnatQNov 15, 2016Aspirant
We are having the same issue on multiple client devices and are having to reboot 6 or so to get the external drive to show up. Really need the fix.
- mdgm-ntgrNov 17, 2016NETGEAR Employee Retired
Please try 6.6.1 Beta 1
- blacky1Feb 28, 2017Tutor
Hi
I'm having issue with backups failing and I believe the issue reported in this thread still exists with firmware v6.6.1.
My hotplugged external USB3 drives are not recognised by the Web UI of our ReadyNAS 104.
I have the USB cable connected to the Rear Top USB port.
The last time a drive was shown as mounted was when I rebooted the ReadyNAS.
For ref, we use Western Digital MyBook Essential 3TB drives
https://www.amazon.co.uk/Western-Digital-Essential-Drive-External/dp/B0042Z55RM
The kernel log though does show when I disconnect one drive in the morning and rotate it for another.
Feb 27 08:33:39 STUDIO_NAS kernel: usb 3-1: USB disconnect, device number 35
Feb 27 08:33:47 STUDIO_NAS kernel: usb 3-1: new SuperSpeed USB device number 36 using xhci_hcd
Feb 27 08:33:47 STUDIO_NAS kernel: usb 3-1: New USB device found, idVendor=1058, idProduct=1170
Feb 27 08:33:47 STUDIO_NAS kernel: usb 3-1: New USB device strings: Mfr=2, Product=3, SerialNumber=1
Feb 27 08:33:47 STUDIO_NAS kernel: usb 3-1: Product: My Book 1170
Feb 27 08:33:47 STUDIO_NAS kernel: usb 3-1: Manufacturer: Western Digital
Feb 27 08:33:47 STUDIO_NAS kernel: usb 3-1: SerialNumber: XXXXXXXXXXXXXXXXXX
Feb 27 08:33:47 STUDIO_NAS kernel: usb-storage 3-1:1.0: USB Mass Storage device detectedBut the web interface->Logs always show the destination cannot be accessed when trying to run the backup.
Tue Feb 28 2017 10:09:19 Backup: Error backup job MWF Backup Active Jobs: destination cannot be accessed. Checking the logs I see:
multiple backup_nnn_error.log files, each containing:
No USB storage was found at usb_port_3:3!
and also multiple backup_nnn_status files each containing the following message with the associated epoch:
BACKUP_STATUS__FAILED!!1487894742!!warn
I can send complete logs if required.
I'm not sure when this issue began, but I do remember with older versions of firmware the web UI always reported the external drives as connected/mounted.
Thanks
- blacky1Mar 03, 2017Tutor
Sigh.. Just had to reboot the ReadyNAS again to mount the external USB backup drive in order to perform a backup. What a PITA.
Wait.. I can't believe it... Hot Swap has just worked!. I'm gonna have to perform more tests now.....
