RaymondBailey
Jul 31, 2021Aspirant
ReadyNAS 6 Pro+ with Tripp lite UPS
Connect and manage with Tripp lite SU5000RT4UTF and installed WEBCARDLX
Sandshark
Jul 31, 2021Sensei
I assume this is intended as a question, beginning with "How do I". You do not state whether you are still runnig OS 4.2.x on your Pro or OS6, though I don't think it matters
The ReadyNAS uses NUT for UPS management. As best I can tell, though, Netgear has not provided a capability to install an SNMP MIB for NUT. It can only use those already listed in the UI, which does not include Tripp Lite. Given the format of /etc/nut/ups.conf (at least in OS6) is non-standard, with references to #dashboard I think they must have made changes to NUT before compiling it.
RaymondBailey
Corect it was a question, apologies but my experience when searching community knowledge bases is less is more, that being said I appreciate your responding so quickly. Also the RAIDiator version is 4.2.31
Tripp lite offers a software package called "PowerAlert" for both Windows and Linux environments and was hoping someone has already been through the process of attempting to use it and share their knowledge/experience. There has to be a better way to use what I have over acquiring a seperate UPS unit to gracefully shut down the unit in the event of a power disruption.
Thanking in advance for the assistance.
