zip2diskuk
Jun 21, 2015Aspirant
ReadyNas Duo - hard drive upgrade options
Hi, Currently I have 2 x ReadyNas Duo sat on my hub and we have various PC and TV access it mostly for streaming movies or backed up storage of photos etc. Duo1 has 2 x 2Tb drives in, 3/4 in use, and...
zip2diskuk
Brilliant, they are v1 I think with 4.1.14 so thanks for the confirmation. I have splashed out on a 104 now thinking that was going to be the case and I dont see me ever needing to go over 16T so I can migrate both Duos out to the 104 once its here. One more question, If I lift a drive from Duo1 and put it into 104 will it be immediately recognised with my data on it already and I can then sync to one of the new drives at a time.... or do I have to insert new empty discs first and then copy files over my network from Duo1 and Duo2 into the 104 ?
Thanks
Tony :)
Thanks
Tony :)
