Angusjdd
Sep 08, 2017Aspirant
ReadyNAS Duo not visible on W10 network for backup
Help ! I have been using a ReadyNAS Duo for a few years now, for data backups. I upgraded to Windows 10 a few months ago and now I cannot the ReadyNAS on the network as a drive. When I open Window...
- Sep 11, 2017
Hello Angusjdd,
I understand that you have a windows 10 computer that is having trouble accessing the NAS via SMB. If other computer able to access the NAS then we can isolate that there might be a problem on this specific computer. Please make sure that computer and NAS is on the same subnet of ip address and does belong to the same work group. You may also try to disable firewall, anti virus and internet security application running on the computer. Kindly check this thread as well it since it may be the cause of the problem.
Welcome to the community!
Marty_M
NETGEAR Community Team
Marty_M
Sep 11, 2017NETGEAR Employee Retired
Hello Angusjdd,
Marty_M
- StephenBSep 11, 2017Guru - Experienced User
Are you able to access the duo when you enter \\nas-ip-address or \\nas-name in the windows explorer address bar? Use the real IP address (or name) of course.
I agree you should try Marty's troubleshooting steps, including checking out the thread on SMB1 (which is what the duo v1 uses).
Another option is to run CMD and try entering
net use * /delete
net use T: \\nas-ip-address\C /user:admin nas-admin-password
Let us know if that mounts the NAS data volume as drive letter T. Be careful on the typing (both spaces and slash direction).
- AngusjddSep 12, 2017Aspirant
Hello Marty and Stephen
Thank you very much for your helpful and prompt replies. The problem was indeed the SMB1 issue. I had disabled SMB1 when the Wannacry virus scare was happening as that was the advice, even though I am running W10. I have now re-enabled it and everything is working fine.
I am still not clear running W10 in a simple home network whether I should or shouldnt have SMB1 disabled, but because I need to use the ReadyNAS I am going to leave it enabled. The various workarounds in the SMB1 thread were above me to understand so I am just going to live with risk.
Great support team - Thank You !
Angus
- Marty_MSep 13, 2017NETGEAR Employee Retired
Hello Angusjdd,
It does appear that the concern was cause by the update windows made for the wanna cry issue. After re-enabling SMB1 every thing is back in business now. If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Marty_M
