Angusjdd's avatar
Angusjdd
ReadyNAS Duo not visible on W10 network for backup
Help !  I have been using a ReadyNAS Duo for a few years now, for data backups.  I upgraded to Windows 10 a few months ago and now I cannot the ReadyNAS on the network as a drive.  When I open Window...
  • Marty_M's avatar
    Sep 11, 2017
    Hello Angusjdd,
    I understand that you have a windows 10 computer that is having trouble accessing the NAS via SMB. If other computer able to access the NAS then we can isolate that there might be a problem on this specific computer. Please make sure that computer and NAS is on the same subnet of ip address and does belong to the same work group. You may also try to disable firewall, anti virus and internet security application running on the computer. Kindly check this thread as well it since it may be the cause of the problem.
    Welcome to the community!
    Marty_M
    NETGEAR Community Team
ProSupport for Business
