Eddie1
Oct 27, 2012Aspirant
ReadyNAS DUO System Partition Full #19755076
After a failed upgrade attempt I am left with a system partition that is full. I this state I can not either upgrade of downgrade. Filesystem 1k-blocks Used Available Use% Mounted on ...
mdgm-ntgr
Oct 27, 2012NETGEAR Employee Retired
As I mentioned in your other thread you should contact NetGear support and post your case number.
