uxphil
Mar 30, 2016Aspirant
ReadyNas Duo v1 disk upgrade - space expansion not shown
Hi, One of my disks in my ancient, but trusty ReadyNas Duo v1 (Firmware: RAIDiator 4.1.14 [1.00a043] ) had died and I decided to upgrade the disks to the following: WD 2TB SATA lll Hard Drive...
mdgm-ntgr
Mar 30, 2016NETGEAR Employee Retired
Disable disk spin-down and try rebooting again.
- uxphilMar 30, 2016Aspirant
Thanks fo the tip, but it wasn't turned on to start with.
That's in System > Power, right?
Or is there another option?
Also, here are the performance options that I have:
Enable disk write cache. = ON
Disable full data journaling. = ON
Disable journaling. = OFF
Enable fast CIFS writes. = ON
Enable fast USB disk writes. = OFF
Power options:
Enable disk spin-down = OFF
- JennCMar 30, 2016NETGEAR Employee Retired
Hello uxphil,
Does the FrontView > Volumes have Volume Maintenance option? Sorry I'm not that sure if Duo v1 has this option, the Intel-based ones have.
If none, since you have backup of the data, maybe you can try resetting to factory?
