soaring_eagle
Sep 23, 2014Aspirant
ReadyNAS Duo v1 HDD replacement problems
Computer: Ubuntu 14.04 LTS laptop Device: Netgear ReadyNAS Duo v1 HDD1: Seagate Barracuda 72000.12 ST31000528AS 1TB (Firmware: CC38) HDD2: Seagate Barracuda ST2000DM001 2TB (Firmware: CC29) HDD...
mdgm-ntgr
Sep 23, 2014NETGEAR Employee Retired
I wouldn't have recommended those disks. The WD RED or the SeaGate NAS drives could be worth considering.
Do you recall what version of RAIDiator is running on your NAS unit?
Are you able to try backing up your data, do a factory reset (wipes all data, settings, everything) and restore your data from backup?
As for recovering your data using an ordinary x86 Linux machine see e.g. http://home.bott.ca/webserver/?p=306
Using X-RAID disk 2 is typically the dedicated parity disk. That's why it didn't have any partitions on it.
Newer models have distributed parity with partition tables on all disks.
