soaring_eagle
Sep 23, 2014Aspirant
ReadyNAS Duo v1 HDD replacement problems
Computer: Ubuntu 14.04 LTS laptop Device: Netgear ReadyNAS Duo v1 HDD1: Seagate Barracuda 72000.12 ST31000528AS 1TB (Firmware: CC38) HDD2: Seagate Barracuda ST2000DM001 2TB (Firmware: CC29) HDD...
mdgm-ntgr
Sep 24, 2014NETGEAR Employee Retired
soaring-eagle wrote:
Sorry, I forgot to include the version of RAIDiator my unit is running. It is running RAIDiator version 4.1.13.
That is the latest for your unit.
root@john-HP-Pavilion-dm4:/home/john# sudo su
root@john-HP-Pavilion-dm4:/home/john# mkdir /mnt/lvm
root@john-HP-Pavilion-dm4:/home/john# fuseext2 -o ro -o sync_read /dev/sdc1 /mnt/lvm/
fuse-umfuse-ext2: version:'0.4', fuse_version:'29' [main (fuse-ext2.c:331)]
fuse-umfuse-ext2: enter [do_probe (do_probe.c:30)]
fuse-umfuse-ext2: leave [do_probe (do_probe.c:55)]
fuse-umfuse-ext2: opts.device: /dev/sdc1 [main (fuse-ext2.c:358)]
fuse-umfuse-ext2: opts.mnt_point: /mnt/lvm/ [main (fuse-ext2.c:359)]
fuse-umfuse-ext2: opts.volname: [main (fuse-ext2.c:360)]
fuse-umfuse-ext2: opts.options: ro,sync_read [main (fuse-ext2.c:361)]
fuse-umfuse-ext2: parsed_options: sync_read,ro,fsname=/dev/sdc1 [main (fuse-ext2.c:362)]
fuse-umfuse-ext2: mounting read-only [main (fuse-ext2.c:378)]
The instructions on the link were not for mounting the 2GB OS partition, but rather for mounting the data volume.
I did view the secondary disk in Gparted and it only showed an 'unallocated' entry
The parity disk appears to be blank to your PC, but it isn't.
Is the procedure different for replacing a disk depending on if it's in slot 1 or slot 2?
Best to remove and replace the failed disk while the NAS is on.
Are there utilities that enable you to possibly fix disk errors?
Disks when they e.g. reallocate sectors will no longer uses the bad sectors. If a disk is having lots of errors then it is failing.
