soaring_eagle
Sep 23, 2014Aspirant
ReadyNAS Duo v1 HDD replacement problems
Computer: Ubuntu 14.04 LTS laptop Device: Netgear ReadyNAS Duo v1 HDD1: Seagate Barracuda 72000.12 ST31000528AS 1TB (Firmware: CC38) HDD2: Seagate Barracuda ST2000DM001 2TB (Firmware: CC29) HDD...
May 01, 2015Guru - Experienced User
I am wondering if you have a full OS partition.
Whether that is the cause or not, I suggest
-backing up the data
-doing a factory reset
-rebuilding the NAS and restoring the data.
Tedious, but probably preserves the most hair :-)
If you can't see all the data from Windows, you can try using Linux Reader (http://www.diskinternals.com/linux-reader/) which can read the data disk (but not the mirrored parity disk).
