soaring_eagle
Sep 23, 2014Aspirant
ReadyNAS Duo v1 HDD replacement problems
Computer: Ubuntu 14.04 LTS laptop Device: Netgear ReadyNAS Duo v1 HDD1: Seagate Barracuda 72000.12 ST31000528AS 1TB (Firmware: CC38) HDD2: Seagate Barracuda ST2000DM001 2TB (Firmware: CC29) HDD...
May 04, 2015Guru - Experienced User
The OS partition is not the same as the C volume, and is only 2 GB on the 4.1.x products, and it can get full. Examining it requires ssh access.
The fastest way to back up is over a wired network connection (gigabit preferred).
You can also access the primary disk data using your linux system's SATA. There is a guide here: http://home.bott.ca/webserver/?p=306
