soaring_eagle
Sep 23, 2014Aspirant
ReadyNAS Duo v1 HDD replacement problems
Computer: Ubuntu 14.04 LTS laptop Device: Netgear ReadyNAS Duo v1 HDD1: Seagate Barracuda 72000.12 ST31000528AS 1TB (Firmware: CC38) HDD2: Seagate Barracuda ST2000DM001 2TB (Firmware: CC29) HDD...
May 07, 2015Guru - Experienced User
Usually the log gets full because of a run-away log file. Though some add-ons (readydlna for intance) that create databases in the OS partition.
The next step is to find out where the big files are. Try "cd /var/log", followed by "ls -l" and see if there is a massive file in there. It is safe to delete all of the log files (del *.log).
There are some folders in /var/log that also contain logs - it is also safe to delete the log files in those folders (but don't delete the folders). For instance, "cd /var/log/frontview/backup" and "del *.log".
