wetenhr
Nov 13, 2013Tutor
ReadyNAS Duo v1 stuck in a boot loop....
My ReadyNAS Duo seems to have some kind of problem. Running 4.1.12. Shares a UPS with my NV+ v2, which is running just fine. It has got itself stuck into some kind of boot loop. It tries to st...
Nov 16, 2013Guru - Experienced User
I guess if the supply is failing that it might not be able to power the unit with two disks in place. Is supply hot with only one disk installed?
