hhtech
Nov 04, 2013Aspirant
ReadyNas Duo V1 trouble with HDD's blue blink forever
My ReadyNas Duo V1 does not work anymore :? Problem description: At power it up it will just blink the blue power led and the fan runs at differents speeds and it sounds like the HDD is working....
aks
Nov 04, 2013Virtuoso
OK, so without disks you can get RAIDar to find it, but with the disks installed RAIDar does not find it. Is this correct?
What IP address is it using (without disks), i.e. are you connecting via a router? Can you check whether it is obtaining an IP address when disks are installed (in the router stats)?
Have you tried a direct connection from PC to Duo and set the PC IP address to 168.168.168.1 (the Duo will use 168.168.168.150).
I'm just checking with RAIDar 4.3.8 now, so it's perhaps useful to find out more what it shows at various stages.
You may need to go right back to a boot recovery process if all else is failing, since you have proved the disks do actually work in your PC:
http://www.readynas.com/kb/faq/boot/how ... t_recovery
