diskomoderat
Nov 21, 2015Aspirant
ReadyNas Duo v1 won't boot anymore after power out
Dear all,
I have been using my ReadyNas Duo v1 (mirrored) for 7 years with no problems at all. Worked flawlessly all those years, initially with 2 x 500GB, approximately 3 years ago I replaced both discs for 1TB ones. Also working fine with no problems. For all those years I thought it was enough to have my data on the nas in mirror mode was a safe enough solution. I somehow thought you could easily take out one of the discs and get the data off in case the nas stopped working and therefore never made a back-up of the nas. Now I know I was wrong since last weekend my ReadyNas duo stopped working. My family photos of the last 15 years are on those discs, hence it's pretty important I can get those back, and I don't want to do anything hastly with the risk to cause anymore damage than I already have done.
What happened?
I had a power cut so the ReadyNas was not powered off the correct way. After restoring power and restarting the Nas it came back and worked as before. I failed to check the logs or let the Nas restart via frontview. Just went to bed, the next day I couldn't connect my mapped drives anymore, couldn't access it through frontview, nor find my Nas in Raidar. I couldn't turn it off so I had to pull the plug. After that it fails to boot properly.
After power on I only get the blue light to flash very quickly and then it continous to flash at a lower pace. The fan running at full speed.
II tried the OS reinstall by pressing the reset button and the power button. The power light would blink very fast and button after about 5 to max 10 seconds disc 1 & 2 would blink shortly, then I released the reset button. But that was it, from then on only the constant blinking of the power light and the fan running at full speed. For a day it remained like that. I've tried it couple a times without results. I did this with both disks in.
I´ve read some more about possible causes and solutions and in my opinion there are only two options: either something with the Nas or with one or both of the discs. Or both. However since I am not that technical I am a bit puzzled of the next step.
Therefore some questions, that hopefully someone can answer for me.
1) Taking either disc 1 (l) or 2 (R) out and trying a restart with only one of the discs make sense or would that only cause more damage?
2) I was thinking of taking my two 1TB discs out and trying to restart the nas with one or two other discs inside. I have the original 500GB discs still laying around so that could be possible, however not sure what effect that would have. And would trying that in any way decrease the chances of recovering my data?
3) I can probably get my hands on an identical V1, would it make sense to try my 1TB discs in another V1? And similar aslo here the question whether that decrease the chances of recovering my data?
Hoefully anyone here is so kind to point me in the reight direction to help me get my data back.
Thank you,
Eelco
- JennCNETGEAR Employee Retired
Hello diskomoderat,
Welcome to the community!
We always strongly recommend to always have full backup of files so that in case if a power outage happens (that sometimes affects disks), you can still grab your files from your backup. The worst thing can happen here is if both disks got affected.
If you have XRAID configured with the NAS, you should still be able to retrieve files as long as only one disk went bad out of 2.
This is possible if you have XRAID level (RAID1), just make sure you label all disks, the order is important. Never swap them. If you are using RAID0, it is not possible because it is a non-mirror RAID.
Files and OS are stored to the disks inserted. If you remove the existing disks and replace and another set of disks, the ReadyNAS chassis will load the OS from its flash memory to the disks, so the new set of disks has a different volume from what you have on the first set of disks you have been using. When you insert the original ones to the ReadyNAS chassis (make sure you insert them to their respective bays, never swap), it should still have its own volume and other settings and files assuming that disks are still good..
3) I can probably get my hands on an identical V1, would it make sense to try my 1TB discs in another V1? And similar aslo here the question whether that decrease the chances of recovering my data?This is okay if you are sure that the disks are good. I suggest you make sure first if those disks are usable.
Try contacting support center, you may avail their per incident service to check the status of the chassis, disks and files.
- diskomoderatAspirant
Hi JennC,
Thank you for your useful comments, let me try some tonight. I'll update later with hopefully a positive outcome.
Regards, Eelco
Hi again,
I managed to restart my Nas with one disc, but couldn't turn it of and reboot it from frontview. The apply button is greyed out / not active.
So i thought maybe I need to resync with the second disc first but that failed after 39%, now it says disc dead.
Still unable to power it off through frontview, not sure what to do next.
Regards, Eelco
