rozel1
Feb 12, 2023Aspirant
ReadyNas Duo V2 - Constantly Blinking Blue LED and Windows 11 RAIDar Installation Issues
Hi all - hope you can help me with trying to sort my ReadyNas Duo V2. I can see the NAS in Windows Explorer fine but the blinking LED is worrying me. Logging in via Firefox does not reveal any...
- Feb 13, 2023
The problem is that you need an old version of java - which is a pain.
This runtime binary will work:
Note you can also get the runtime sdk from Oracle, but you need to create an Oracle account to download it.
This is in the second section (titled "Java SE Runtime Environment 8u202"). It appears to be a bit older than the first link (which is version 221) - no idea why that is the caes.
If you ever uninstall this stuff, you need to uninstall RAIDar first, as the uninstall will fail if it can't find the java runtime.
rozel1
Thank you for your speedy response - much appreciated. Answers are: -
I'm using 5.3.13 - it's definitely a Duo V2.
The LED immediately below the on/off button.
No I want RAIDar so I can choose whether to use RAID or not.
Feb 12, 2023Guru - Experienced User
That is the disk activity LED. Blinking isn't necessarily a problem, though it might be useful to sort out why the disks are always being accessed.
One thing you can try is disconnecting the ethernet cable for a while (maybe 30 minutes or so), and see if that changes the behavior.
One long-standing bug in RAIDar 6.5 is that it doesn't have the feature that lets you choose XRAID vs FlexRAID with the legacy NAS. You still need RAIDar 4.3.8 for that.
- rozel1Feb 12, 2023Aspirant
The blinking has stopped! By pure coincidence I did disconnect the ethernet cable earlier and having reconnected it, all seems perfect now.
I still want RAIDar, whatever the version. Given the issues detailed in my original post, may I ask what I need to do please?
- StephenBFeb 12, 2023Guru - Experienced User
If you want to run FlexRAID, then download RAIDar 4.3.8 from https://kb.netgear.com/20684/ReadyNAS-Downloads#raidar
It likely will also say that it needs Java. If it does, then you'll have to install it.
No idea what Java install error you ran into (or even whether you installed from java.com or openjdk.java.net). So if you run into that issue with 4.3.8, then you will need to provide more details.
- rozel1Feb 12, 2023AspirantI've described the issue and sadly the issue is well documented, bar a solution.
Maybe someone else can help?
