talkingduck
Aug 19, 2012Aspirant
Readynas Duo V2 - Raid1 and xRaid2
I've been reading through a few posts here and the documentation(RAIDiator 5.3 SW Manual_3Jul12.pdf) and have a few questions about how to setup my RAID. I have a Duo V2 which means I have a maximu...
talkingduck
Aug 20, 2012Aspirant
Thank you for the replies, the biggest worry for me is if the unit fails and I can't find a replacement system for xRaid2 drives.
Since the Duo V2 does not support xRaid1, I assume those people with xRaid1 formatted drives are stuck (well if you couldn't buy the old Duo V1 second hand). If the Duo V3 comes out and doesn't support xRaid2 I will have to use a Linux system to copy my data to the new system. If I was using Raid1 presumably I could just plug these drives into any supporting Raid1 unit and carry on?
Is the only real advantage of xRaid2 over Raid1 the ability to swap 1 of the drives for a larger size? For example if I wanted to upgrade my data on to larger disks I would replace DISK1 with a large drive wait for the unit to resync the data and the replace DISK2 with an equally large drive and wait for the sync?
