fitwizard's avatar
Jun 29, 2021
ReadyNAS Duo V2 - Synology DS1517+ transfer using rsync
So I've finally upgraded to a new NAS (Synology DS1517+) and need to transfer about 3TB of files across from my ReadyNAS Duo V2.
A mate said to use rsync, but I haven't been able to get it working via a backup task on the Duo.
Do I need to use an SSH terminal?
Is there a guide for dummies somewhere?
Cheers!
  • I doubt you'll find a how-to that covers those two products.  rsync is a standard Linux protocol.  It's a client-server protocol, so you need to have it set up on both the source and destination.  It's hard to say which end(s) are causing your problems, especially since you gave no details.
    On the destination, you need to make sure it's set up as an rsync server to both send and receive via rsync (read only is often the default) for the device overall and the destination share and set the user name and password to be used.
    Setting up an rsync "push" job from the DuoV2 to another Linux client is pretty easy.  Create a backup specifying the source share and the destination as "rsync server".  Then fill in the details for the destination on the area to the right and verify the connection is good using the test button.  Then, just run the job.
    • fitwizard's avatar
      fitwizard
      Tutor
      Hi SandShark,
      On the Synology:
      I have enabled the rsync service under File Services
      do I need to enable the rsync account and if so edit any of the account settings?
      do I need to set any advanced permissions on the shared folder for rsync to work?
      On the ReadyNAS:
      rsync protocol is enabled on the share I am testing
      I've created a backup task with the share as the source
      I assume that if no path is specified it will copy everything?
      backup destination is type remote, name remote: Rsync server, host is ds1517 (the name of my new nas on the network)
      if I test connection it says "successfully connected to ds1517" and when I run the task it completes successfully but no files are copied
      do I need to set login and password?
      if not, what account does it use to connect?
      admin account is disabled
      guest account is enabled and has read/write access to my test folder
      cheers
      • StephenB's avatar
        Try specifying a specific share on the ReadyNAS (in the path), and run the job again.
ProSupport for Business
