cbiggins
Feb 25, 2017Aspirant
Readynas Duo v2 3 flashes
Hi All, The last few days my ReadyNas has not been able to start up. All LED's flash 3 times followed by 2 x "1" LED flashes. I have tried the ReadyNas with individual drives but this mad...
mdgm-ntgr
Feb 25, 2017NETGEAR Employee Retired
Your profile indicates that you have a Duo v1 hardware revision 2.
I'm not sure from your description but it sounds like you could have run into the "No disks detected" error.
Does your NAS show up in RAIDar?
cbiggins
Hi mdgm,
Its an RND2000 v2.
No, it doesn't appear in RAIDar.
- mdgm-ntgrFeb 25, 2017NETGEAR Employee Retired
Can you confirm from reading this article: How to tell whether I have a Duo v1 or Duo v2 or NV+ v1 or NV+ v2?
Are you able to power down, hook your disks up to your PC and test their health e.g. test your SeaGate disks using SeaTools and your WD disks using WD Data LifeGuard Diagnostics?
- cbigginsFeb 26, 2017Aspirant
So, according to that post, it's a V1 (http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/duov1rearlayout/)
But, under the unit says 2000 V2.
I'll make sure I say V1 from now on.
I'm on a Mac, maybe I can use the in built tools to test them?
- cbigginsMar 01, 2017Aspirant
So, the available tools to us Mac users are limited.
I plugged the drives into my Macbook and while Disk Util was only fairly limited in functionality, I could see an issue with one of the drives.
With this in mind, I see myself having 2 options;
1. Replace the drive with the same model (unavailable from new, I would need to buy a 2nd hand drive.)
2. Replace both drives with some nice new drives. But, if I do that, can I get the data off my 1 good drive to put on the new ones?
I'd love any info/suggestions/recommendations.
Thanks all.
