leahcimd1
Sep 10, 2015Apprentice
ReadyNAS Duo v2 Flashing Backup LED
Hi, I am having a problem with one of my ReadyNAS Duo v2 units. Firmware version is 5.3.11. I powered down via the Dashboard web interface. When I powered back up about 10minutes later th...
- Sep 10, 2015
You cannot just put the disks into the 102, they will be wiped.
Your best option if you have another duo v2 is to use that chassis to access the data and copy it to the new 102 when it is set up. Make sure the firmware on the working duo v2 is up to date first.
Dont mix the disks up and label them ( the ones from the broken duo and those in the working duo) according to slot number.
Sep 10, 2015Guru - Experienced User
Why the http://www.mydigitalpix.me.uk/ link?
Is the duo still covered by warranty (3 years for the original purchaser). If so, contact support. This sounds like hardware to me.
You might also use RAIDar and see if it gives any more status.
leahcimd1
Hi StephenB,
Hardware warranty expired on the 20th April this year.
Raidar cannot see the ReadyNAS
The green LED on the LAN connection is on with occasional blinking.
- vandermerweSep 10, 2015Master
Are you absolutely certain that when you push the reset button the switch is engaged?
It is certainly an ominous sign if you cannot access the boot menu.
You could perhaps check that the memory is seated properly and try again.
What happens when the unit is booted with no disks, and also with another spare disk that you know is good?
- StephenBSep 10, 2015Guru - Experienced User
I'd try these tests first (at least the no-disk boot).
- leahcimd1Sep 10, 2015Apprentice
Sorry for the delay, been away from PC.
The same thing happens with no discs.
I haven't a spare disk that is on compatibily list, but I do have a WD 500GB Green drive (WD5000AAVS).
vandermerwe wrote:You could perhaps check that the memory is seated properly and try again.
How do I get access to do that?
You would need to open the chassis. I don't have a duo and I'm not sure you'll find an instruction manual for this.
I think StephenB is right though and you need to consider how much effort you are prepared to go to.
