theokr
Jul 28, 2016Aspirant
ReadyNAS Duo won't expand
When I bought this ReadyNAS, it had 2 drives in it, each 750GB. Now, I've added new 3TB drives and it simply won't expand - I'm stuck at 750GB. Nothing happens. The satus is just "Healthy". The c...
theokr
Aug 05, 2016Aspirant
Yes, I did a new install. I put 1 new drive in and did a full factory reset. Then I read online that expansion won't ocur with only 1 drive installed so I installed the 2nd 3TB drive and still stuck at 750GB.
I installed the ForceExpansion add-on from the netgear site which did nothing also.
So basically, no hope in even expanding the volumes to the NAS maximum of 2TB. I was (incorrectly) under the impression the latest firmware would allow this.
In the end I gave up and bought a Synology which sounds defeatist but that worked out of the box no questions asked, no config required.
Aug 05, 2016Guru - Experienced User
As I said here, your duo was not capable of working with disks > 2 TB.
Any current ReadyNAS of course would have handled them with no problem.
