fkomlosi
Jul 12, 2012Aspirant
Readynas Duo X-RAID to RAID0
Hi all, I have a Readynas Duo with a 1TB and a 2TB drive, running X-RAID. I want to achieve maximal space, using two raid0 volumes (redundancy is not an issue). Could someone please tell me if I can ...
Jul 12, 2012Guru - Experienced User
Generally cat 5 is out of spec for gigabit speeds. Though if the cable length is short enough, you can often get away with it. If you have a cat 5e or cat 6 patch cable, that might speed things up a little.
